Úvod > Fórum > Software > Windows všeobecně > lokalizace/help
lokalizace/help
08.01.2009 08:50
Using the Orca tool create simple self-installing Windows Installer package that installs by default
two TXT files(example1.txt, example2.txt).
- example1.txt should be installed by feature called „Approot“ into „C:Program FilesOurExample“ directory
- example2.txt should be installed by feature called „Approotopt“ into „C:Program FilesOurExampleSecondTxtFile“
- feature "Approot" is ON(it means that feature „Approot“ will be installed by default)
- feature „Approtopt“ is OFF by default, user can choose if this feature will be installed
- installer should consist of UI wizard where user can change installation direcotry
- user also can turn on or turn off installation features
- the package is prepared to receive a major upgrade
- the same Installer package must be capable to uninstall installed files
Note:
- It's Microsoft technology, please check their web site for all necessary and relevant information.
08.01.2009 08:51
nejaka rada?
zkusenosti s orcou?
